95 seaddoo gtx 657x keeps running
nacar
Finally I have my seadoo running, but does not shut off after I disconnect the kill switch plug. I read that somebody had the same problem and installed a toggle switch and temporary fix the problem. I sent a message to him but I want to know another member has the same problem and can post pictures of how they did it.
Thanks in advance
No need to rig it adding cheap switches that don't hold up in moist conditions. Just take a multi-meter and confirm weather or not your lanyard switch is working. If it's not then replace it.
Thanks Matt for the replay, Do I need to take the electrical box out to test it? The box is a PIA to take it out, so any idea how could I test it?
Yeah you don't want to probe the wires from the outside because that just lets corrosion in. You get better at getting into that pain in the but e-box every time trust me.
