bryankipp
I recently purchased a 95 GTS. I have been through some minor issues with it but it runs strong "when" it runs. We had it out over the weekend. Ran very will. Anchored it and took it out to play several times. All was good. Started it to head home, fired right up. As soon as it was given throttle, engine died. Currently I don't get a click from the solenoid at all. I have tried jumping the solenoid and have even gone so far as hooking a jump box directly to ground and to the starter. It will turn over at that point. I replaced the battery and have removed and cleaned the cables. I have also done continuity checks on the start/stop button and kill switch. I do know a few weeks back the hull was half full of water (covered the battery) but the electrical box was clean and dry. I still suspect one of the two switches since it did start and was running, but I could be way off base!
Any ideas where to look at this point would be greatly appreciated!
