I have a 99 XP 947 that I picked up recently. The engine was wasted by the previous owner so I rebuilt it. The engine runs well, but the issue is
1. the tuned pipe gets very hot after a couple minutes of operation and
2. hardly any water exits on the left side of the hull.
The cylinder and head just get warm, not hot.
The pressure regulator on the muffler leaked, so I installed an o ring to see if that would fix it. It didnt. I replaced the water regulator housing, it still leaks, and still hardly any water coming out of the left side of the hull.
I blew out all of the coolant lines during the process and the engine passed the leak down tests. There is no evidence of water in the combustion chambers.
According to the diagram, most of the water to the tuned pipe comes through the head/cylinder and exhaust manifold, then to the pipe. If the engine is cool, then it is getting water. if the engine is getting water, then shouldnt the pipe be getting plenty of water? Some water is directed by the pressure regulator, but it would seem most of the cooling is done by water from the engine itself.
Any suggestions would be appreciated!
