94 SeaDoo SPX
Fern
Hey there i Need to change the wear ring on the Sea-Doo wondering if this is the right model 271000101
And the impeller looks pretty decent but since I'm in there should i upgrade it.. is there a better one than stock or is it all pretty much the same
Yes, that wear ring should work. You can upgrade it, but it’s a give and take thing, so if you pick up some top end, you’ll lose some bottom end...
would you know if pretty much all wear rings are the same there's not too much difference in them?. Then I should just keep the stock impeller
Seadoo really did a good job selecting the stock impeller. If your ski is stock you really can’t do much better. So if it’s bad just send it to Impros for refurbishment.
For the wear rings there is only one and for your ski, 140mm. I like the OEM ones the best. Some of the aftermarket ones don’t fit correctly.
