94 sea doo gtx, how to clean carbs?
kiddandy
just bought a 94 gtx and was wondering how to clean the crabs on it, it hasn't been running for 2 years, got it running and now would like to clean them. i am new to sea dooing and everything will help!Thanks in advance.
Crabs
if your ski has crabs your in trouble there hard to get rid of but if you want to clean the carbs first pull carb then buy kit then take carb apart think ....remember what you take off and how or vidio yourself then rebuild with kit set high low needles to turns spec its easy and will help
Make sure you also get the needle and seat with your carb kit. They usually don’t come in the Mikuni kit depending who you get it from. Also, remember to get the carb base gasket and pop off gauge to test them. With out the gauge you wont be able to know if you did a good job.
