not2high2fly
I picked up a non running gtx with the old fuel lines hoping that was its problem I swapped them out. I don't have a pressure tester but I blew into the lines and hit all the connections with soapy water and am 99% sure that I don't have a leak. The problem is I'm not pulling any gas from the tank I swapped the OEM fuel filter for a inline so I could see and no gas is feeding from the tank. If I prime the carb's she start's till the gas is used up so now I figure look at my fuel pump and or pulse unit? What kind of pressure/vac should be coming from the pulse port, what does it run off ? Any other ideas? Does anyone have a pic or diagram of the fuel system the previous owner butchered everything. THANKS FOR ALL THE HELP
