787 RFI oil pump not closing with the throttle
jlotruglio
The oil pump on my GSX RFI opens with the throttle but remains open when the throttle is released, almost like a spring is missing. I had the engine out this is my last hurdle I hope. Anyone have an idea what I have going on. Thanks
If the spring it there you probably wound the arm in the wrong direction when installing the able so there is no return tension on it.
No, it's on the oil pump. If you turn the oil pump arm the wrong way the spring will disengage and not close the arm.
