Jnz
I am having what I believe to be carb problems on my 98 speedster. I rebuilt both carbs using kits from shopsbt and prior to this I used a kit on my 787 gsx and had no problem. I've been reading that most places don't sell genuine Mikuni and the aftermarket causes problems. I have one motor that fires right up the other takes a little more work to get it initially started. Restarts don't seem to be a problem. One engine will hit the rev limiter and the other falls on it self at about 3k. The first few times it died trying to go past and after a 2 more attempts it just would sit at 3k, not strong like its hitting the neutral safety but stumbling. I have pulled the carbs apart and they are clean, nothing in the filters and have two external Mikuni fuel pumps. Compression is 150 across the board both motors. Prior to taking them apart this time I pressure tested them and the seats held pressure no bubbling and I switched the springs out to black ones to get pop off set right. The only issue I was having a hard time with was getting the covers to seal it seemed to want to leak down until I tightened the screws with a vice grip to get them tighter than with a screw driver. Now my question is, are the aftermarket kits really causing me all this trouble ? If so, do they need complete kits again or are there separate parts I can order genuine of to take care of the issue ?
