Michael Hunt
One of my Speedster's engines seized a little while ago due to a big end failure of one of the rods. Bless SeaDoo for making a twin engine boat otherwise it would have been a really long paddle back.
I removed the engine from the boat and stripped it down to the case. I knew I needed a new crank as one rod was seized (original engines, LOTS of hours, got my money's worth). Loosened 12 of the 14 case bolts (the 2 bolts snapped below the head, rear-most bolts of course) and worked on them a bit to try and separate the halves.
Spent a little time on the 2 bolts until I found out I could buy a 720 case for $80. Now my newer crank would have a new home.
Cleaned the new case and noticed that there was sealant even in the case grooves for the RV seals, all bearings, end seals even the rear metal shim. I have the SeaDoo manual and it only mentions smearing sealant (515) just on the case rails and buttoning up the bottom.
I can see smearing a little sealant around the end seals to the case, but not everything. So what's the proper or smart way to seal the case halves together?
Thanks for any help.
