Hey guys, what do you think of the Fizzle 4" air intake kit? I'm trying to compare the Riva, R&D and the Fizzle one... The price of the Fizzle is low compare to the two others...
Thanks for your input...
Check signature for mods...
Sent from my Nexus 4 using Tapatalk 4 Beta
Thanks for the reply guys, difference between front and rear?
Yup saw the rebate... Can I put the 10% also?
Well if you're building your own its cheaper since you need less materials and also it is a much shorter hose/tube so it should flow better, in theory anyway. In reality I don't think there's a performance difference unless you ride with the rear seat off which I wouldn't advise.
I don't run one. I have a mesh screen over the top of the tube held in place with a hose clamp. You really don't need a filter if you're drawing air from inside the hull. It's not like you're operating in dusty conditions and as long as you keep it sunny side up no water either. The screen just keeps large things out like if by some miracle a screw comes loose or whatever and makes its way to the intake.
yeah i just have a velocity stack at the end of my kanaflex.. i ran with a filter maybe two trips and the difference is night and day..
lucky for me i have a buddy who owns a major kanaflex dealer a couple towns over.. 10 bucks later i had 8 feet of hose.
But, is it dangerous for water ingestion? A velocity stack?
Also, since the installation idle RPM is changing from 1600 to 1700 ... Is this normal? Is not stable ... before it was 1700 ... Now it's moving from 1600 to 1700 to 1600 ...
I would look into replacing the plugs.. Normal idle is around 1800
