WILakeBoating
Long time lurker and I can't say enough how much this forum has helped me. Kudos to all of you.
I have a 2001 Challenger 1800, 240 EFI M2 and am on season two of owning it. Changed the plugs near the beginning of last season (along with port side temp sensor as a preemptive since I wasn't getting top speed) and top speed restored; it worked great all year. Was winterized and gone over by a pro in the fall of last year and he said I'd need to get it out on the water once this season (just did that two weeks ago) and then change the plugs since they'd be probably fouled from winterizing/fogging.
It ran okay that first time out this season but did this thing where it would rev to what I intended and then lose power a little, then get right back to the correct power - rinse and repeat for anything over about 3k RPMs while cruising. Almost like someone was jerking around with the throttle but VERY quickly. Felt like it was missing intermittently on one or two cylinders but I'm no mechanic. I do not think it's the TPS or Coils/Trigger since the most likely issue is just fouled plugs so that's what I'm doing first before digging more.
So anyway, I thought I was getting a deal when I bought new plugs mid-winter and made the bonehead move of buying NGK BP8HS-10's instead of BPZ8HS-10's. I didn't realize the Z was missing until I had them installed and was putting everything away (facepalm). Have not turned it over yet. I already ordered the correct ones to install for this season.
I understand from googling that the difference between the Z and not the Z is the resistor which reduces some EMI noise, possibly also a heat rating difference?
Questions are:
-If I fire this thing up with BP8HS-10's installed is that going to screw up my ECM or something else?
-If they don't damage the engine and just will foul faster, are these ok to keep as a spare on board?
Thanks in advance!
Questions are:
Thanks in advance!
