So thanks for adding me to the forum. Had an issue this weekend sucked up some rock and banged up impeller and wear ring but not bad. I shut the engine down and got towed back as it wouldn’t started sounded like a rock had stuck in the impeller. I’ve pulled the pump and there was a rock but after taking to off I was going to crank it just to verify everything ok and the Starter would hit but no crank. I pulled the plugs to hand crank it and each cylinder is full of nice clean oil. Any ideas on what I have done. The rocks didn’t seem that bad and I shut off the engine it didn’t stop on its on with the rock?? It’s only got 41 hours on the engine and it has to be related to the rock incident as it was Running fine before.
Thanks for the thoughts? am I screwed… further investigation in the last 10 minutes tells me it was water in the cylinder. Could I have back fired water up in to cylinder? I was ona pretty switch river is it possible it was forced up the exhaust while I was trying to deal with the rocks?
