Can't remember the fault code but at first it was indicating a faulty throttle valve. Removed and cleaned it up and then took the cover off. Some really flimsy wires in there between the plate and terminals, I swear it looks just like 1/32 solder and barely held in place. After reassembling it all I noticed that it had great power and top end but would not idle unless I partially covered the intake. So it looks like my cleaning of the intake has resulted in a map signal that is way out of wack and therefore there must be a problem says the ecm....
Whats involved in making this thing relearn what a normal map signal is ?
Its expecting much more restriction in the throttle valve than exists at the moment.
What interface would be best to use? Candoo or Buds ?
