Chris0260
Hi,
The shifter on my 2012 Seadoo 210 wake is very stiff to engage, then has a lot of play. The issue is specific to the mechanical portion of the shift that controls the neutral/reverse gates; the throttle itself is very smooth.
Here is a short clip (you can see the play/give in the shifter at the 4-5 second mark):
Dropbox - IMG_1392.MOV
Does anyone else have the same issue? I had a tech look at it and he told me that the stiffness and play are both normal. Can anyone confirm if this is actually the case?
Thank you,
Chris
Thank you,
Chris
