2010 Wake 155
AntrimMark
Hi, I'm looking at buying a used Wake 155 with 160 hours on it, 2010 model. Is there a noobs guide to things I should be looking for and if so can someone point me in the right direction?
Thanks,
Mark
Good long test Drive in sport mode , Wot (full throttle) as much as you cant if there’s any code or issue it would thow it out. And if you have somebody that has a compression test kit take it with you.
Check the keel to see if the ski has been beached for too long. I paint on the keel is gone, this is not good wear.
Thanks.
Can anyone tell me what the UK equivalent of XPS Spray for the engine is, I can't seem to find it locally?
Thanks,
Mark
Found some duck oil spray that should do the same thing until I can get some proper spray.
I was washing the salt out of the engine compartment however the water drain out very slowly with the drain plugs screwed out. Is this normal? I tilted the boat till the back of the trailer was on the ground. I think they may be blocked but can't reach them from the inside and when I eased a pen in from the outside I met some resistance after a few inches. I'd rather not shove it in hard unless someone says that's the right thing to do...?
