Michael211_2000
How much engine oil does a dry 4-TEC engine hold? Every drop of oil was removed from the engine, the case split open, more oil poured out... you get the idea?
I've so far put 5 quarts into mine, and it just now seems to have stabilized on the dipstick at the full mark.
After 3 quarts of oil and the 1st 20 minute run on the water, it went from full on the dipstick to down to the very tip of the stick! Yikes! It wasn't burning oil (the exhaust was clear no smoking) and it doesn't appear to be leaking oil inside the hull (the bilge is clean and what little water drains out of the bilge plugs is just lake water). The dealership said it takes 3 quarts to change the oil... but I've now put a total of 5 quarts into this engine! Does changing the oil in 1 of these engines only replace 3 quarts worth perhaps?
Anyways I'm perplexed and hope somebody can explain where the oil went in there... I figure it's all still gotta be in the engine somewhere.
Thanks.
- Michael
Thanks.
- Michael
