Broken_Sportster
So i buy a Sportster the other day, 2nd time on the lake, i suck up the tubing rope. I didnt back over it, just while sitting with the engine off, the current sent the rope under the boat towards the intake. I see this, pull it out, and then start the engine; apprently it worked its way back very fast because it got sucked in. I didnt realize it and didnt think it was a rope (seeing as how i had just moved it) and it sucked up into the intake. The boat chokes for a couple seconds and dies. I check my fuel gage and 2 cycle oil tank and both are fine. I start back up, chokes for a couple seconds and dies again.
After this, i look at the rope and see its under the boat. I swim under the boat, and the rope is wedged between the hull and the intake grate (both ends of the rope are wedged and a lot of rope has gone up into the intake.) So, now the engine wont start so i start oaring my way back to the ramp with the help of a buddy until we finally can flag someone down for a tow.
We get the boat out, back home, and take a look. There is about 25 feet of rope wrapped around the driveshaft starting about 4-6 inches from the engine compartment, all the way to the impeller ring. (i guess there was a little luck that none had hit the impellar.)
So, i start cutting all i can get through the grate, and this rope is REALLY stuck up in there. I take off the impellar grate and pop a dang bolt head (one of the long forward ones... i was unaware there were lock nuts on the inside of the engine compartment.)
Well, i got the intake grate off but there is still a bolt sticking about half an inch out of the bottom of the hull. I cut away as much rope as i can... probably about 24.75 feet of the 25 feet of rope tangled up, but i cant get a little piece that seems stuck up under the impeller ring. I assume this means i will have to take out the entire propulsion system.
So to my questions.....
Is there any nice step by step guide on how to take out the propulsion system, starting from the VERY begining and VERY detailed? I am somewhat mechanically inclined and i am an engineer so i love detail. (or, preferably, is there a way to get that last bit of rope out without removing more? i have tried cutting with a small as a paring knife and tried pulling at little bits with a pair of needle nose vice grips.)
Question #2 - Where inside the engine compartment is the lock nut located for the forward bolts for the impellar grate. The more detailed the better, pictures if you have them would be even better.
Any help would be GREATLY appreciated. I am really upset that my new toy is broken (especially at the end of the boating season.) PLEASE HELP!!
THANKS ahead of time
