"MAINT" will show on the display (when key is first installed) every 50 hrs of operation. It's just a reminder that service is due. (oil change, etc.) A scanner will be required to reset this or just ignore it. If "MAINT" appears while riding the ski then the MPEM is telling you there is a problem and you should then press the set button 5 times in order to get the code.
