Help. 2005 GTI. Here is the problem, hope someone can help. The “boys” got a bunch of fishing line tangled in the impeller. They flipped it over in the water to remove the line. After getting it out and flipping it upright it ended up with water in the engine.
After many hours of work I got most of the water out. It now starts,idles and runs well Up till about 1/4 throttle. To get it above 1/4 throttle you have to chokE it a little to get it to rev up. It then seems to run good at full throttle. The next time you slow down to below 1/4 throttle you have to go through the same procedure. We ran it for a good 1/2 hour still the same. I have checked the fuel filter a couple of times, no water in the gas.
Any body have any a idea what is going on?
