2003 sea doo speedster with Mercury 240 efi
tkalb22
I have a 2003 sea doo speedster that starts right up and runs for about 1 minute and dies at idle I’m not sure what it could be. I have a video of it dying if that would help anyone with trying to figure out what’s going on. It seems like it’s almost not getting enough fuel but has a brand new fuel pump and fuel filters have been cleaned out.
it is now making a continuous beeping but has a full tank of gas
Hi, I had the same problem with my Challenger 2000. It kept beeping even with a full tank, it turned out that the Baffle Float (picture attached) inside the Fuel Tank Baffle Pick Up Sender (picture attached). For some reason they get filled with fuel.
Where is the video?
Check your vst for continuous fuel flow in. Set a catch can under the vst. Loosen brass screw (on side, near bottom). Turn key ON. You should have continuous flow as long as the lift pump runs. If flow stops, before lift pump stops, your vst inlet needle may be stuck. Not allowing full flow into the vst.
