2003 gtx supercharged gauge and info center failure
fplomb
Guys i have 2 gtx supercharged limiteds. Both speedo
and tach with infomstion center have gone
Dead. Any help?
Frank
Hello: Check your wire connections to the gauge and check your fuses. Everything just doesn't fail something should still work..
Norm
open up your fuse box area and the 1amp fuse goes to the gauges. Its the box to the left of the battery if looking from the back of your ski. Also you can always take the gauges out of the hood area, simply get a flathead screw driver and behind the black hard plastic that goes all the way around the gauges pry the gauges out gently and then when you pull them out disconnect your gauges and shake the gauges to see if you have water inside of them. I actually recently pulled mine out to find the gauges half full of water. Let us know what you find out as I am currently in the same boat as you. removing the water did not actually help me out but I have heard where it did help others.
