Just repaired the head on this machine that had slight water damaged on the #3 cylinder. Unit was reassembled, compression was 160 psi on all 3 cylinders. Stared up and ran pretty good with no exhaust cooling water. Only ran for 30 sec two different times. Hook water up to the flush port in the rear and ran agin. This time tthe longer it run (2 mins) the worse it got. Stopped immeadiately and check compression agin. All was well. Started agin, harder to get started and things got worse. I was loosing power. Remove plugs agin to check compression and found lots of water coming out of the spark plug hole. How can this cooling water get to this point. What likely has failed?
Unit has been dried out and waiting on me to return. Unit was running better better but not on all 3 cylinders. Suspect foulded plug
Rick
Rick
