Nikon22042
Greetings everyone,
I have a 2001 Islandia (240EFI) that has several issues. 1 being low compression (60psi at idle) which seems to be an old engine issue. The boat will get to WOT but doesn’t quite have the speed to get on plane. Borescoping the pistons shows no wear or galling, spark plugs check out, all seems okay but that rings look worn (will replace in the off season). The other seems to be a sensor issue. When testing the 1st issue the engine pulled back power and idled high (3300rpm) like limp home mode. Pulling the throttle back to idle reset the issue. It is sporadic so we’re going to look at the CAN signals to see if we can figure out which one it is. Any advice on either issue?
