oh I thought the drain line was 8mm/ 1/4, that's a 12mm hose, and below that there is a 1/4 clear hose that runs to the same spot under the motor by the front also I thought that was the drain line? what would that be for?The one with the arrow should go to the side of the block and drains the cylinder. It shouldn't run up to the front of the engine like your second picture.
I remember the 12mm ones being the feed up to the top of the cylinder and the pipe.
I am pretty sure the 8mm cylinder drain hose connects to the garden hose fitting that your arrow is pointed to. I think it necks down in size on the inside of the hull
I am pretty sure the 8mm cylinder drain hose connects to the garden hose fitting that your arrow is pointed to. I think it necks down in size on the inside of the hull.
Let me see if I can get by and look at my 01' this weekend, it is currently in storage.
ok so this clear line that's a 1/4 line is the cylinder discharge that goes to the back under the other 12mm hose. and the 2nd 12mm hose will go to the coffman pipe thats not installed yet which i should of just mocked up to get a better visual of all this.Correct, only two 12mm hoses. One goes under the pipe and the other on the top middle of the cylinder. I just don’t remember where the two connect at the pump side.
well the water lines on the pipe are and I jetted the carbs, I just needed to figure out if that clear 1/4 in line was the cylinder exit and I believe it is and got it all hooked up today, just have to finish putting the new sponsons on then I can get the water box mounted and pipe in and wrap this up.Wait! Coffmans pipe? That’s way different than OEM on water routing and carb jetting.
