I have a 2000 RX with a 951 Carb engine.  I rode it two weeks ago and it ran perfectly.  This was after installing a new battery cables with an anderson connector so I can disconnect more easily.  I also had the carb off at that time in order to replace the fuel accelerator lines.  I checked the carb filters and they were fine.  It ran great after these changes.
However, when I took it out today, it was sputtering and what I assumed was misfiring. I thought it might be a little water in the gas (I use red Stabil) but it never got any better.
While idling, it would jump from 1000 rpms to 2050rpms. It would do the same thing at higher rpms as well if I tried to give it some gas.
After 15 mins or so trying to run the bad gas out of it, I took it out of the water. At this point, I don't think it's the gas, but I'm not sure what I should be looking for. I pulled the spark plugs and they appeared a bit fouled to me. They've been brown in the past.
Any ideas on some initial troubleshooting steps?
