First of all I'm new to the forum. I've been around boats and water craft all my life but new to the pwc world. I recently purchased 2 matching 2000 seadoo gti's with the 718 motors in them. Both started and ran great when I viewed them yesterday and today they have serious issues. Basically I was took. Now onto the good stuff:
Jetski A
Went to start this morning, turns over and I'm not getting spark. I researched a little bit and found that I should check the white wire on the coil for voltage. It should read 15v+ I'm not getting any voltage. I read that the cdi box would be the culprit. So I took the cdi box from Jetski B and installed it. Same problem, no spark. I Natalie's cdi from A and put it in B and B fires up no problem. Cdi is not the issue. So I swap the cdi back to correct ski. I pulled coils and swapped. No spark. So I'm stuck on this one.
Jetski B
This one starts up without issue. Idles really nice for the 1 min I will allow out of water and shut it down. I put it in the water and go to take off. Doggy as all hell. Does about 10-15 mph. After about 20sec to a minute of 10-15mph it takes off and runs pretty good. Feels like it's loaded up so I change plugs. Put in ngk br8es from factory sticker. Samething is happening. It'll idle no problem but at wot it'll only do 10-15mph then it'll get up and go for a few minutes before dropping off. Changed cdi boxes with other ski and same issue. Jetski A has a newer Cdi box from 2007 and Jetski B has oem. What should I look for because I'm in need of direction.
Thanks to all that reply!
Jetski A
Jetski B
