Billkandel
I have a 1999 Sea doo GSX RFI that was running only at high RPMs in the water or would it stall. It also would not idle in the water and just stall out. Then one time it would not start at all, but turned over fine.
It will run great out of the water at any RPM, then the second we put it in the water however it will not start at all now. We checked the compression in both cylinders and they were 150 each. We also took apart the head to check for any gaskets that might be blown, everything was fine. The TPS was professional adjusted. Right now we have the exhaust apart checking for blockage and have not found anything. There was a bunch of water in the muffler, but i believe this is normal?
Any input would be awesome! Thanks!
