1998 Bombardier GTS not restarting
seadoosyd
Hey there Seadoo forum!
I own a 1998 Bombardier GTS PWC and it’s been having issues restarting.
The jet ski will start fine on land and when it first goes into the water. It’ll run perfectly fine and then after turning it off and leaving it (whether it be 5 min or overnight) it will turn over but not fire. I took it to a seadoo dealer and they said it had the wrong spark plugs, so they replaced them. Started right up, ran great, stopped it to drop a friend off at the house, then wouldn’t restart as usual. Please help!!
We need to see if it is an electrical issue or a fuel issue.
What do you have to do to get it to finally start after it has been sitting?
Are you turning the fuel selector off immediately once you stop it? Does that help?
Doe sit seem flooded like it will not fire without holding the throttle wide open and cranking for a while?
Also... Welcome to the forum. Please don't post in multiple locations as it makes it much more difficult for us to assist you.
