kaylaskorich
So I just bought this 97 seadoo GTX from a guy 2 days ago and tested it on trailer and everything seemed perfect. Beeper works and everything sounds like it’s running just fine. I’ve tested it twice in the water and each time it will run perfect the first time I turn it on but once i push the button to turn it off and on again it goes completely dead.
The First time; I start it and run it for about 5 minutes then press the start/stop switch to turn it off. there’s a buzzing that keeps going after it’s off and key is pulled, i’m thinking that was the starter, then battery died. I did also noticed that the solenoid was getting stuck. When I took the ski out of the water and charged the battery it started up, but no beeps.
The Second time; doesn’t make sense? I put it in the water again, started it and runs perfect for about 2 minutes so i press start/stop switch off and get my life jacket quick and ready to go out. I take key off and put it on again and absolutely nothing happens. no beeper. no gauges. no sounds. nothing. and battery is at 12V and it ran perfect a second before that? So put it on trailer and take it home, put the key on and it beeps and runs on trailer!
I really just don’t understand what’s going on please help!
