hello i have a 1997 gtx and it will run and rev fine for about 10 seconds, then it will go to stall due to too much air or not enough fuel, as when i pull the choke out for a split second it picks up again and runs fine for another 10 seconds.
the coil is new, the carbs have been cleaned, i have ran it with a seperate fuel supply to eliminate hoses or blockages.
the problem is strange because when it is started to revs perfectly then all of a sudden it starts to flood with air, so when i choke it it picks up and runs fine.
i dont know if it has something to do with the rotary valve, it only has42hours on the clock.
any help will be apreciated
