Hello All,
New to the forums, hope you all can help. I bought a ‘97 GTI from a guy at work. It needed a top end. All done and back in the water. It has the newer accel pump style single carb like a ‘98. Carb is brand new. Problem I’m having is it idles perfect. On top end it seems good. The issue is the middle. If I punch it from a slow speed, it will just maintain lower rpms forever and not rev out. It’s not missing or cavitating, I’m mechanical enough to know I’m good there. If I slowly walk it up to about 1/2 throttle, then punch it, it stays at same rpms for about 2-3 seconds then pulls up to full throttle like a snowmobile. Like it’s hitting a powerband. It never bogs out and dies, just no throttle response. I’ve done the fuel lines, oil lines with tygon, and fuel filter. Fresh 93 octane fuel. Machined the rotary valve cover back to spec. I even put the old non-accel pump carb back in after a rebuild, and it was worse. Wouldn’t get to top end at all! I’ve unplugged the rectifier, nothing. PLEASE HELP
