Hello. New to the forum and trying to get my 96 XP on the water.
Symptoms-Starts and idles fine out of the water. Revs out of the water. Hard to start in the water. Does not rev in the water. Sometimes hear burst of air coming from the carbs when running. Here are the things that I have checked/replaced-Compression=150 on both cylinders, Rebuilt both carbs with Mikuni kits (pop off at 28 and replaced needle and seat), Rotary valve cover replaced from SBT (still getting .020 doing the squish solder test with new cover which is out of spec), confirmed rectifier is good. Any thoughts or suggestions would be greatly appreciated. Here is a youtube link to it running in the water. Thanks for any help/suggestions.
