superdoo22
Hey all, I have a 1996 seadoo spx that I picked up off a guy in nom start condition. Replaced the cdi box causing a no spark condition/ replaced the plug wires/caps. Took carbs out and cleaned out the filters/any crud. Replaced all fuel lines with ss clamps. Cleaned out fuel selector valve. 150 psi in both cylinders. Put a new wear ring in. Ran great for maybe a day or two and then died on the water under throttle. Restarted and still have good bottom range throttle up to mid range then it won't gain any more rpms, it doesn't want to get off plane. Took carbs out and checked filters. Almost spotless but one had a little crud in it. Set high speed to 1/8 and low speed to 1 1/4 put it back in the water same issue. Closed the high speed and I can't tell maybe it runs a little bit better but not sure. Took red plug off rectifier and also didn't change anything. Can't find this issue on the forums and I'm at a loss. What would cause a lack in the ability to get high rpms? Should I go back to the carbs? Is the fuel selector valve leaking air but only when I'm trying to demand wide open throttle? Any help is appreciated
