Donkendave
Hey everyone,
I have a 96 GTI that's all original and in great condition, goes 52 mph as it should, wear ring clearance looks good at a glance (need to measure still), fuel and airlines appear in great shape, impeller appears in great shape, engine compression is 137 on both cylinders, carbs. look good as well as their filters (just cleaned filters 2 weeks ago) and gas filter just cleaned as well. So last Saturday I found myself in 6" of water with sand below, unfortunately I panicked and rather then killing the motor, I hit reverse and then proceeded to get back in forward and drove out. Within 1 minute I heard a loud, high pitch winding sound (only one time, lasted about 3 to 5 seconds) and the ski began sounding extremely rough and lost power. I tried cruising back with no throttle but within 5 minutes the engine temp light came on, I shut it down and got towed in. Since then I have done a compression test, examined the spark plugs, bumped the starter with plugs out, examined the shaft, impeller & wear ring, blown out the the water intake line (felt clogged for half a second and then blew through, thought that was it but no cigars), ran water through the coolant system in both directions; runs fine in the driveway but horrible when you put it in water. Next, I guess I will check out the impeller shaft reservoir and bearings to see if sand got in there possibly. I would have thought this would've been a common, easy to diagnose scenario, but I'm not finding anyone else that has experienced this problem. Any suggestions would be greatly appreciated.
