stinger520
I recently bought a 1995 SPI waverunner from someone who claimed it ran fine. He started it up for me in his driveway off of the water house adapter and it started right up from cold. I put it in the water the other weekend and heard an alarm from the unit. After investigating a few items (we started it several times using the garden hose adapter), the alarm later went away. The owner had started the unit with running the water before starting the engine, I have now learned that can cause damage and you should only start the water after the engine is running
I then took the unit out for about 5 mins brought it up to some RPM to get some fresh fuel running through it. When docking the unit and starting and restarting it, the engine seized. We took it onto land, and were able to break the shaft free and restart the engine (Just started and turned it right off to see it would still run).
I suspected oil may not have been mixing properly. I took off spark plugs and put a tiny bit of oil directly into the cylinders to make sure there was at least some oil in them. I started the waverunner with one of the oil lines removed and saw that the pump was in fact sucking up oil. The oil system also appears to hold pressure.
So does anyone have an idea of what might have gone wrong/is wrong with my PWC? I'm considering to just pre mix my gas to be on the safe side. I've greased the engine shaft in the back. I don't know what type of oil was in the unit, but I've now bought the real Seadoo low ash stuff to use.
Did starting the unit a few times with the water running before the engine was running cause the engine to seize? Anything else to investigate? Should I just premix the gas and hope for the best?
Thank you in advance for your time and consideration of my questions.
