mike molzen
Hello, I have recently joined Seadoo Forums as a member. I am hoping that you can help me with a problem I am having with my 95 Sportster. I have been reading some of the other posts regarding wear-ring problems. I purchased my Seadoo last summer from a gentlemen who had purchased new and kept it garaged all it's life. The boat looks outstanding and was well maintained. At the time of purchase, the seller had told me he had replaced the wear-ring and impeller. I used the boat three times on a large fresh-water lake with no problems (approximately 5 hrs of use in all) During the 4th trip I launched the boat as usual with no problems, but when I attempted to accelerate the engine rpms jumped but the boat acted as if it wasn't getting a good bite in the water. After  backing-up a few times the boat improved. I could get the boat on plane if I accelerated slowly. I crawled under the boat and shined a flashlight to check the pump impeller. I noticed the new impeller and the black wear ring. I didn't see any obstructions or even a nick in the wear-ring or impeller. This spring I took the boat back out, and wouldn't you know it, it didn't fix itself over the winter. Eye-balling the clearance at the impeller, I would guess the clearance is with-in your mentioned .040" tolerances but won't be able to check until I purchase a feeler guage tomorrow long enough to check. Prior to checking the tolerances at the impeller tomorrow, are there any other possibilities that could cause worn wear-ring symptoms. Any help would be greatly appreciated.
