biggdoggs1
QUESTION 1 / I am trying to remove the PTO flywheel, someone told me I could put a rope thru the spark plug hole to jam the piston and use a pipe wrench on the PTO. Is this safe or would it damage the needle bearing or cages.
QUESTION 2/ Before I bought the boat, the guy changed the batteries, and know the gadges do not work. the starbord MEPA fuse 7.5 amp is going to ground if he crossed the wires could this have damaged the controll board? QUESTION 3/ When taking off I have about a 5 second delay on the port engine before boat can plane out. Could this be the carbs, or is it normal?
