Hi, I have a 1995 GTX, and the thru hull fitting is shot/deteriorated (seadoo part 292 000 075). The driveshaft rotates around and the rubber sleeve wants to rotate with it. I contacted my local Seadoo dealer, and he has the fitting in stock. He also recommended replacing both double lip seals and the needle bearing that are contained in the seal carrier, which makes sense. The rubber sleeve is in good condition with no tears or punctures.
Does the above make sense? I've downloaded the repair manual, and it doesn't looks like it's too difficult of a job. Any hints or tips or things to watch out for would be great!
