I have a 1994 SPI which I just put a new to me 587 into. Old one the fuel injection failed and cooked the motor. Now it’s premix with seadoo oil and 40:1.
While apart I replaced the grey lines with black and rebuilt carb. It fired right up, no choke necessary. Put in water and it would idle and let me give it about 10%throttle. If I idled long enough I could go WOT for about 2 second and it would cut. Almost like someone pulled the tether, but it was still secure. After 3 times of that I decided to stop to avoid damage and idled back to the launch. It spit and sputtered a bit, and seemed to run better when choked partially. This to me says lean. So I am wondering if something got clogged in the fuel pickup. Mine doesn’t read fuel level anymore so I wonder if that’s an issue?
Any thoughts greatly appreciated. When it quits it just quits, no spitting or sputtering.
Here are the plugs, but that’s after idling back to launch about 4-5 minutes. I am also using BR8 vs the recommended BR7 because no one had those available and I have 8s for my quads.
