Joey White
I've finally got my seadoo running great... well at least I thought. It turns out it doesn't want to turn off (reason I didn't know about this was because it always died when I tried to test it before). I thought it might be the tether cord button that was sticky because it wouldn't even turn off if I took the key out. So I grabbed another one off my parts seadoo, that did not fix my problem. The stop button is also not working, but I am more worried about the key because I want it to turn off if I fall off. This is the diagram that I have been using for the electrical and by following it, it has not solved my problem. There used to be a programmable coil that the spark plugs went off of and when that was installed the key and stop button both worked.
