john.g.gillett
After much investigation by Seadoo Dealer I am still experiencing cut outs above 5500-6000k rpms and wondering if anyone has had the same issue?
Engine sounds and goes great, was rebuilt last year, oil regulator valve failure, and has only done 5 hours since then, boat has done 58 hours in total. Acceleration is fantastic with engine revving right up to 8100 but when I plane out, after about 5-10 secs the engine momentarily cuts out then starts up again and will continue to do this until it stops. However, if I pull back the throttle to below 5500-6000k it will sort itself out and will cruise there happily. Have changed all the sensors, coils, the fuel pump and regulator, both fuel filters, cleaned out the fuel tank and pressure tested the intercooler but can't seem to get rid of the issue. About to replace the ECU as the only thing not replaced?? Anybody experienced this and can suggest a fix please?
Many thanks.
Many thanks.
