So to the point, my question is "Does anyone know the PN(s) for exhaust manifold gaskets for this engine?"- 2007 Challenger 180 (215hp). The parts catalog doesn't seem to show/list them. I cant believe its just a metal to metal seal...
Now for all those who are asking why and want to read the long winded story (input welcome). I have been having an ongoing starting problem mostly when the engine is hot after shutting off and sitting in the water for a hour or more. Replaced plugs, coils, injectors, fuel filters etc. it happens fairly regularly and once the boat starts it may run rough initially but cleans up rather quickly and runs flawlessly. I recently came across some info of the same exact problem caused by water ingestion, either from a leaking IC or a leaking exhaust manifold. This makes perfect sense with my issue and would also explain why the dealer was unable to duplicate it in the shop as they shut the hose off before shutting the engine off which would give it enough time to purge the manifold of water and eliminate the problem from occurring. Anyway I pulled the IC and pressure tested it in water- it looks to be in great shape and I could not for the life of me get any bubbles to come out when applying air pressure to test it.
Since I do not have a tow valve installed my next step is to try and install a tow valve on the cooler line and close it shortly before shutting the engine off with the hope that this will closely duplicate the conditions the dealer tested it under and reduce the amount of water in the manifold, in turn reducing the amount that leaks into exhaust chamber and presumably fouls out the plugs when I am unable to restart it. If I am wrong, I will have installed a tow valve and I can move on, no harm/no foul. If this improves/eliminates my starting issue, I would still like to repair it before it gets any worse. Thus requiring removing and repairing/replacing the exhaust manifold- at that point I would also be inspect/test the water jacket in the manifold to prove out my theory.
Would love to hear from anyone who has pulled one of these manifolds especially if it was for a similar concern. Open to constructive input...
*Prior thread; C180 Hard Start after sitting for an hour
