Hi, many thanks in advance for any thoughts on this one... I've got a 98 GTX with the 12V Low warning and the ski bogs down after running it several minutes.
Things I've checked:
- I checked the battery and tried a battery from a working ski as well. The batteries are charged and working fine.
- I checked the voltages on the MPEM to verify the stator is not the issue.
- I suspected the voltage regulator/rectifier, which unfortunately is built into the MPEM. The guys from OSD Marine for an external voltage rectifier and they didn't currently have the parts to make it.
- I bought a used MPEM for my ski thinking that would do it, but I still have the 12V Low warning.
I'm at a loss at this point... not sure what else it could be? Also, I should note that I swapped out all the old gray hoses and did a new carb kit. The ski runs great for the first few minutes and then once it starts to bog I have to pull the key and put it back on to reset everything.
