05 rxt burning oil and have chocolate milk for oil
tants2011
Hey everyone im new here and to sea doos , my 05 rxt has been running great but it has 130 saltwater hrs on it and i live im Florida so there is no winterization my spark plugs look white so that is evidence of water or moisture it would not start for me so I took it to the shop they put 3 plugs in it and it started right up I took it for a water test for about 1 hour full throttle and my RPMs were 7700 so that kind of rules out intercooler leaking correct? So today I took it out again and I had water and my hull and a quart low on oil and it looks kind of chocolate milk and it did it start after it ran great at proper RPMs for over an hour can I please get some input because it's going back to the shop on Monday thank you in advance
I don't know anything about these skis but since someone worked on it, could the hoses have been swapped by accident during the process. Water should not have gotten in to the oil and the damage could be serious. System needs flushing and checks to determine where the water came from.
Anything is possible but it did worked on at a very reputable shop and it was burning oil and smoking before he worked on it, as far as the water in the oil its not white its more brown and the level is low if it had alot of water mixed with my oil i would think the level would be higher on the dipstick , im also getting water in my hull ...i did read that that can be caused by the SC sucking in water ?
