01 XP How much power is this motor making?? 135HP or 185HP IM CONFUSED
Skidmore01XP
Ive got an 01 seadoo xp, wondering if anyone knows how much power the motor is making. Somewhere i beleive on the title it says 185HP, someone questioned it and i have no clue how to tell.... Also is it fuel injected or Carborated. Its only a 2cylinder and down on the back side of the motor where the throttle cable hooks up feels like a thottle body but it could be a carborator im really not sure. Any input it appreciated.:confused:
If it is the 2 stroke (twin cyl), its probably got a 951 engine and that is rated at 130 hp. It should have a tag between the pto and the cylinders that tells about the engine. At least mine do.
I believe you have the 951 = 130HP and if so you have carburetor's, just look in the engine bay you'll be able to see if you have carbs or if you have a DI motor.
