MxRacer965
Hi all,
Been lurking around here as I just bought a 00 GTI this Spring and did some general maintenance like rebuilding the carb (clogged fuel filter), replaced all the old tempo fuel lines, fixed the fuel baffle resistor, pump oil, new beeper, etc. This forum has been hugely helpful so thank you all.
On to my situation that I could use some help with. It's been running great until the 4th of July when suddenly while cruising along mid throttle the engine started cutting out while I noticed the speedo fluctuate rapidly up and down with no rhyme or reason followed by the ski shutting off. If I press the start button I get a single beep unless I remove the lanyard and put it back on again and it starts right up. It may run fine or it may act up. I've had instances as well when the oil light will come on while all this is going on, and I've had the ski beep before as well. The only consistent symptom that goes with the cutting out is the speedo rapid fluctuations. So far it also seems to happen after more extended riding or when I'm out getting aggressive in the water with water splashing everywhere. I disconnected all connections and applied fresh dielectric grease and that didn't resolve, it has new BR8ES plugs (just in case) as well.
My first thought goes to the MPEM failing since it is the brains behind all the things that are going haywire. What are your thoughts?
I did get a new regulator that I intend to try this weekend to see if that might be it, but I'm not too hopeful. It hasn't been jumped since I've owned it. I did put the battery on a charger but it was out of the ski.
Anyway, any insight would be appreciated!
Aaron
Aaron
