Ah... I Missed the part where you replaced the carb.
Well you could still check the pop-off pressure. I'd expect it to be in a good range though. I find the skis run much better with the pop-off in the higher range.
So.... I have two 1996 and a 1997 GTXs. I rebuilt the carbs side by side same settings.... everything. Both skis responded almost the exact same. I tried the 23psi that I got with the initial rebuilds. Then I went up to 27 psi pop-off and they got a little better. I went up to 33psi pop-off and they were pretty good at the transition and I was cool with it. Then I replaced the needle and seat and put in the correct Mikuni spring and HOLY SMOKE there was such a difference. The ski went from ...
1. Are you giving me more throttle? I am offended that you don't like this speed. I'll just gargle with the extra fuel. You'll get the message.
2. You wanna go faster now? OK... let's see what I can do.
3. OK OK I"m coming hold on a second.
4. Ok, lets go....
5. I'm ready when you are slick... hang the hell on !
