Greeting, so I purchased a used 2021 RXT-X300 this spring, ran it few times this summer and all was OK.. I happened to check the oil while on jet ski port and noticed it was over the full marks, but figured it wasn't level and didn't do the procedure, so left it. Now , winterizing it, I sucked out 5 quarts of oil, following the steps, 2 minute run time etc, and cranking it wide open throttle for 10 seconds a few times to extract more oil....Was it over filled ? Specs say 3.2 qts oil change with filter, capacity 5.3 qts.
