Information center
I have a 2003 Seadoo gti le rfi my info center is stuck on mph everything else works fuel gauge warning light I have ck the mode button was not working replaced still does not change any help would be appreciated
I haven't worked on that specific problem but I'd check the connections and wire condition. You can probably cut/bypass the button and physically cause the intermittent contact needed to change modes. Good Luck
Did look at wiring put new mode switch still won’t change just not sure even though everything else work on gauge could it be a bad garage ?
