Hi. We accidentally ran our Trixx with the raw water cooling valve off (I installed the valve since I tow the Seadoo regularly). After a short time, it indicated it was hot and went to linp mode. After opening the valve and allowing it to cool, it would run at idle but would stall when trying to accelerate. I removed the deck and found the Exhaust Gas Temp Sensor is broken and the Resonator inlet is partially melted. The muffer inlet hose also appears stressed. Please see attached photos. It is clear I need to replace the sensor and the resonator. What do you think of the muffler inlet hose? Any tips on changing these parts? Anything else I should check or replace? Thanks for your help!
